kann mir jemand sagen, von wo bis wo im Projektor ich die Anzahl der Perfolöcher Zählen muss, um das Delay richtig einzustellen?
Pascal
Soweit ich weiß, Abstand Bildfenster-Mitte bis Kamera vom Cat. 700.
Ggf. zur Feinjustierung (am besten zu zweit) den Prozessor bei laufendem Projektor zwischen Digitalton und Analogton hin und her schalten und dabei nochmal nachjustieren, bis keine Verschiebung mehr hörbar ist. Denn was hilfts, wenn richtig gezählt wurde, aber trotzdem eine Verschiebung da ist?
Pascal
Hallo Ernemann,
Auszug aus dem DA20-Manual:
STATIC
1. Thread a length of Cat. No. 1010 Digital Soundhead alignment test film such that
the “bullet” frame (perf 106) is located in the picture gate, and perf number 26 is
located at the analog soundhead.
2. With the length threaded through the Cat. No. 700 Digital Soundhead, read the
number of the perforation present in the light path of the Digital Soundhead. Dial
this number into the Cat. No. 611 CP interface card switches SW1, SW2, and SW3.
3. Verify the accuracy of the setting by running a loop of Cat. No. 1010 test film and
observing that the flash on the screen coincides with the pip in the sound.4-3
Wenn Du keinen Cat.1010 hast, musst Du also beginnend bei 106 die Perforation zwischen Bildfenster und Cat.700 auszählen.
DYNAMIC
1. Thread a loop of Cat. No. 1010 through the projector, analog soundhead, and
Digital Soundhead. Run the projector.
2. Locate SW5, the top rotary switch on the Cat. No. 611A Cinema Processor Interface
Card located between the analog signal presence LED and the Dolby Digital LED
of the C.P. Status slot in the front panel of the DA20. Set SW5 to the position 9,A,
or B depending on the Cinema Processor type (see section 4.1)
3. Monitor audio from the center channel of the DA20 while simultaneously
monitoring audio from the analog tracks through the Cinema Processor. This may
be accomplished by setting the cinema processor to format 05 (SR) and monitoring
the analog audio normally, while listening to digital audio from the DA20 on a
separate monitor circuit. Headphones may be connected to J8 pin 20 (center
channel) and J8 pin 1 (signal ground) by means of an adapter to monitor the digital
audio (consult Dolby Laboratories for additional information).
4. Adjust SW1, 2 and 3 for minimum delay between the analog track and the digital
track.
5. Return SW5 to the correct Cinema Processor position (see section 4.1)
Gruss, Gruss
