A lot of the users here means, the sound of the CP500 ist bad. I think, the sound of the equipment depends of more than only the CP500. It works wth the AUD DA2.
Please remember, the CP500 is a piece of the early 90´s, incuding the d/a converters - 16 bit.. at this time, this was the "state of the art" but nowadays, with uncompressed pcm-sound and the higher dynamic range of d-cinema systems - everything is better as to keep the old processor in the system.
if your booth does not use 35mm, the best thing is to improve your sound is to put out the old CP and install a newer processor like the AP20 or USL100, when you´re using 35mm, take the USL80 and a DA-20 for DolbyDigital.
