My Bauer P8TS has no sound but visual part is fine. Internal/External speaker stays in mute even I tried with paper strip to the optic sensor.
After disassemble the projector it turned out the fuse on bottom board (Si1) is gone. Tried to replace it but it keeps blown away.
When I asked in 'Teknik' section before(my original post has been deleted now. Assuming category matter, I am sorry for the mistake..) somebody suggested to check if C37/38 is damaged. But based on what I am seeing from the service manual, I can't find C37 or 38.
Is there anyone could give me a tip or some suspect point that I need to inspect?
Typically, the big capacitator that is located behind the 4 diodes (Graetz-circuit) is short circuited and may have killed at least one of the diodes. You must check and replace it. To get there remove the base plate and the circuit board, unsolder the parts...
  Am 18.8.2020 um 18:27 schrieb jacquestati:
Aufklappen
Dear jacquestati,
Thank you for the advice. I will check that first and would do feedback. Hope it works!!
